[ROM DOWNLOAD] NEW FIRMWARE 0703 FOR MK808B WITH NEW WIFI CHIPSET
    Hi as the MK808B has been changed with new Wifi chipset. The new ones need new firmware.
    Today I’ll share with you the new firmware. Pls check with our service people with your order number If you wanna flash this firmware
    Download link: MK808B New Firmware
    Password: geekbuying.com
    Eidt:
    How to tell if you get the new bulk or old bulk?
    It’s very easy, the new bulk with RTL8723 chip will have the series number in the mk808b, such like the following photo:
    Best Regards!
    GeekBuying
    This is not new rom but the stock rom that this stick comes with. And it has stuttering issue with mx player and beyond xbmc which the now older version with RK903 wifi/bluetooth chipset didn't have. Is there a fix for the stuttering issue? Are they working on a new rom that will address the stuttering issue? I ordered 5 sticks and they all are the new realtek ones, and are pretty much useless because of the stuttering problem.
      If someone can donate me a stick, I'll make a KitKat rom for it.
      Already have KitKat running on MK808 with my own kernels.
        I can donate you a stick, and it doesn't have to be kitkat rom, all i need is a rom that will solve the video judder/stutter issue. I actually prefer the 4.2.2 rom and if possible with a 1080p kernel.
          OK
          I might be able to use one of my previous roms or make a completely new one.
          I will also make a new kernel, that will greatly affect performance.
          The device has RTL8723 wifi right?
          I think someone already posted a dmesg for it.
          I have the original MK808 but with RK903 wifi. People have been trying to make kernels with working wifi for over 1 1/2 years for it, but still no luck.
          If I can get a MK808B new version, it would really help, then I can finally run KitKat on it.
          You can PM me for more info etc.
            I know it has a realtek chipset, but don't know the number, I just looked at the actual tiny chipset, it's hard to read, but I can see the first two numbers are 87 so it's probably RTL8723.
              downgrade to 4.1.1
              Eidt:
              Best Regards!
              GeekBuying
              I am one of your customers. Netflix, xbmc is an issue with this.
              Is there a ROM to downgrade this to 4.1.1?
                ill post new rom later tonight with netflix fix.
                  tired
                  Tired gonna go to bed. This will be just beta..Had to oc gpu and ram slightly. 466 on both. You have to use latest spmc....it is in the rom but you have to load it yourself. Install script is not working right. Other than that works well with all my hd content. Netflix works.
                    Ok. I will wait for your link to post.
                      Eidt:
                      Best Regards!
                      GeekBuying
                      Hi
                      Do you have a rom to downgrade to 4.1.1??
                        OK
                        Did u ever get around to making a custom kernel or rom for the RTL8723 by chance? If so, could u please direct me to the link? Thank you.
