Pipo M9 Pro KitKat 4.4.4 Rom
The only way I have been able to generate a ROM is with a dump from someone's tablet.
If you can provide me with a complete ROM dump (I don't need userdata, though...that's your stuff). Use the ROM dumper tool from one of my ROM kits and follow Finless Bob's directions in the readme file.
What I need is:
parameter
kernel.img
system.img
boot.img
recovery.img
The thing is...I'm on vacation starting today and I won't have time to do any ROM work until sometime next week.Randy
it needs a JB kernel, for now I took the stock RK31 Kernel 3036 M9 Pipo 2
The required 1.24 loader is included. You need to flash this one if you previously had Rileyrom KK as mentioned in multiple other posts here.
Only issue I have found for now is that the cam is rotated 90 degrees.
If someone knows where I should look to fix this?
I had the camera problem on a previous Rom from Oma (Rom for M9 Max (not pro)).
I replaced '/system/lib/libcameraservice.so' with one from an official Rom to fix the problem.
Originally posted by kheno View PostROM is very stable. But GPS/Bluetooth do not work. Camera is 90 degrees turned, so sorry, not as good as I had hoped.Last edited by SirHastur; 24 July 2014, 12:20.
hello, I tried to install the version 4.4.4 but it does not work it crashes on startup omni logo, can you give me the march forward for the installed
1 Basic rom on the shelf
2 dump 4.4.4 has instaled
3 procedure for instaled
thank you
because I would really like to move in 4.4.4 because my m9 too laggy browser (google chrome) and this version should work well
There are currently 2559 users online. 1 members and 2558 guests.
