[SOLVED]Arnova 10b g2 3g with dongle
    hi,
    I have recently bought an arnova 10b g2 tablet and would like to use a 3g connection on the tablet. I found out that archos 3g stick is compatible which is quite expensive and I am looking for a cheaper alternative. I read somewhere that HUAWEI E160G does also work. Can anyone confirm this? or can suggest a cheaper alternative?
    ----------------------------------------- UPDATE ------------------------
    I have tried HUAWEI E176G and it worked out of the box! I will make some test about the stability and update the post.
    solution 3G with ARCHOS G9 3G STICK + ADAPTER USB CABLE
    solution is:
    1) using adapter-cable USB female type A to micro-USB male type B;
    2) connect stick ARCHOS G9 3G to the USB female type A;
    3) connect adapter-cable by micro-USB male type B to ARNOVA 10b G2;
    4) from SETTINGS-WIRELESS & NETWORK SETTINGS-MOBILE NETWORK-ACCESS POINT NAME
    - insert NEW APN
    - put correct string for your provider (my for example: wap.postemobile.it) and exit
    5) from NETWORK OPERATOR
    - try SELECT AUTOMATICALLY
    - come back out SETTINGS and wait for connection 3G signalled by little icon on up-right side, near wireless icon
    that's all
