1. Ensure USB Debugging is enabled in the UT1's (Settings/Developer Options/)
2. Connect the Ugoos UT1 to a Windows PC via the UT1's mini-USB port.
3. After you plug-in the USB cable to the PC, the device will be detected and the drivers installed (direct Windows to the folder where the UT1 driver files are located.
4. After the UT1 driver has been successfully installed and the device is detected, go to the folder where you extracted the files and open the RK3188 folder and run the TPSparkyRoot.bat and follow the instructions.
5. After you boot and then reboot the UT1 again (reboot twice) you will then have root access.
Feel free to ask any questions and comment below.
