SPMC 13.2 (XBMC fork) - RK Fixes/4K Support/AC3-DTS Passthrough
Re: SPMC 13.2 (XBMC fork) - RK Fixes/4K Support/AC3-DTS Passthrough
Originally posted by Koying View Post@tampametal Check permissions. Serach "amlogic permissions" in the xbmc forums.
Sent from my Minix Neo X8-H using Tapatalk.
Originally posted by Koying View PostNope, I'm on stock.
You can PM me the debug log of a failed subtitle download.Originally posted by BTR11 View PostThanks koying; Ok, that´s the problem, the issue reported is related to the interaction between SPMC 13.2.1 (first solving freezing video issue) and this last one SPMC 13.3.2 and the kitkat rom running on Minix X7; same X7 with KK rom does not have subtitles issues with Gotham official or the new Kodi alpha 2; I had running alongside with your version.
But do not get me wrong, there is not an "error" downloading subtiltes, they are downloaded just fine, simply not any character / letter is being appeared or shown on the TV screen whilst the video is playing.
I will provide by PM more details.
Question With Ugoos UM2
I use SPMC and i am very happy with it .
Is there anyone who knows how to get AC3/Dts passthrough working on the Ugoos UM2 ?
I have the Wasser 1.01 kitkat firmware in combination with SPMC.
The stick goes right into my Marantz 1604 receiver but i only get noise if i turn on Passthrough.
Hi guys,
I'm a very happy user of this masterpiece named SPMC!
Tried Gotham and BeyondXbmc--both had acceleration problems on my Tronsmart Mk908 II.
Still I got a little problem.I can not find a subtitle plugin named XBMC subtitle...I found only a standard subtitle plugin.
Using XBMC subtitle plugin would give more setting options...for example the one called "load the first sync subtitle found"....
Any ideas?
N
There are currently 1933 users online. 0 members and 1933 guests.
