Netflix Control - New Owner Frustrations
    I have a Minix X8H, A2 remote, and a Harmony Remote.
    Is there a way to map play/pause, fast forward/rewind to buttons so that it works in NetFlix and HuluPlus?
    Or do the play/pause, fast forward/rewind buttons only work when running XBMC?
    I have no idea..
    But if you were a netflix customer and specially considering that you are from Canada I would have get the Fire TV instead.
    For instance with the X8 and other android devices you will never get hd quality unless someone hack the app or netflix stop being so.... ungrateful ?
    Sent from my ADT-1 using Tapatalk
