Is there a way to get to the file system so that i can change the boot animation?
help with brick
help with brick
I decided i wanted to change the boot animation so i downloaded one i like and copied it into the system media folder and renamed the old one. I then rebooted the device and it's stuck at boot with no animation. Won't boot into android for me to undo what i did. What i failed to do is open up the zip to look at it. I opened up the zip on my phone and now see that it was meant to be flashed. The boot animation was within the zip.
Is there a way to get to the file system so that i can change the boot animation?Tags: None
I figure the best way to fix it is to flash a boot animation at the loader but when i do it says "E:footer is wrong E: signature verification failed install aborted.
Update: i downloaded flashable boot animations an im getting signature verification failed and then it aborts.
Finless can you make me a stock boot animation that is flashable? I promise never to change it again.Last edited by isham.padron; 13 July 2014, 02:16.
We don't delete posts. I will close this for you.
There are currently 2987 users online. 1 members and 2986 guests.
