Many may not know what that is but it is scripting .sh support on boot. Like running the V6 SuperCharger scripts etc.
So scripts that I have personally written that look for available disk space like on /sdcard or /external_sd are having a problem.
It's like WTF?
All partitions or file systems show up on this ROM, or any other rk3066 ROM I have tried, as 0 bytes in size and 0 bytes available! Seriously.... WTF?
I have tried every busybox under the sun, tried all kinds of other system files, etc. But bottom line no matter what... any tool you install to look at NON-ROOT file sizes, does not work! Even tools that are ROOT are not reporting disk space properly!
A prime example. Install ES file explorer and PROP /system. It should tell you how big the partition is, how much space is used, and how much is free. Again try this with the /sdcard. It should at least tell you how much is free! All these tools ALWAYS report 0...... WTF?
I am exhausted on fixing this issue and thinking it might be a kernel problem.
ANYONE HEARD OF THIS BEFORE?
