I have problem caused by the process com.android.media that is slowing down my Minix.
When I connect an external usb Hard Disk this process keeps running for hours slowing down the system.
I googled around and found that probably this is a process that scans media files and it takes so long because there are many media files of the hard disk.
I tried to stop from running applications the media related applications and also tried to put a ".nomedia" file in the folders of the Hard Disk to avoid media scanning, but nothing worked.
Am I the only one facing this problem ? Do you have any suggestion on how to stop this process ?
Thank you in advance for your support.
