I did something stupid and changed the DPI setting from 160 to 240. Now after a reboot, the system starts but immediately system.ui stops working and I am notified of this with a dialog box. When I click OK, the dialog pops again with the same message, blocking me from all access to the UI. Is there a way I can fix this? How can I change the DPI property in this state? Can I plug it to a PC and access the system files (build.prop)? How can I get into recovery mode?
DPI change, now system.ui is broken
Hey guys,
I did something stupid and changed the DPI setting from 160 to 240. Now after a reboot, the system starts but immediately system.ui stops working and I am notified of this with a dialog box. When I click OK, the dialog pops again with the same message, blocking me from all access to the UI. Is there a way I can fix this? How can I change the DPI property in this state? Can I plug it to a PC and access the system files (build.prop)? How can I get into recovery mode?Tags: None
There are currently 1958 users online. 0 members and 1958 guests.
