Hello
I have Pipo M2 no 3g, and I tried to upgrade firmware, I think I upgraded whit wrong firmware cuz my tablet wont start anymore, I connected to charger, nothing happend, now, my PC dosent make any sound when I connect whit USB
can someone help me, give me some advice?
If the tablet won't start...there is a sticky thread in the Pipo forum with instructions on how to get your tablet into flash mode manually. Try that...and flash the stock firmware from Pipo.
Randy Freaktab Developer, Product Reviewer, Moderator and "Flashaholic". Read my BIO Here
Be sure to donate to support Freaktab.com. If any of my development work makes a positive difference for you, please make a donation to support future RileyROM's. Donate here
Make sure you are using the USB cable that came with the tablet. That's the most common cause.
Also, make sure you are using a USB 2.0 port. 3.0 isn't supported.
