NEW JUST RELEASED OFFICIAL CR11S/CS968 2MP/5MP AP6210 ROM Build 7/10/2014
Originally posted by Tech1 View PostThat Gotham 13.0 XBMC has been modified by CloudnetGO, uninstall your XBMC builds ... {Please Note: You have to configure the remote SETTINGS in the XBMC for it to be recognized} ...! Go to the Gotham website download their latest version XBMC, reinstall it ... Now concerning the icons, always use the new latest "Mashup 140" addon, open it follow the instructions, it will auto set up all your icons for you .. New Gotham 13.2 XBMC Beta Download HERE http://xbmc.org/download/#devbuild ...
Will follow your advice Tech1 and post my results here. Thanks for all the support.
Originally posted by buhohitr View PostHey, it nice you're testing Tech1 rom. I'm testing the factory rom. We should see pros and cons after a week or two. So forth, I found no issue with stock rom running build in Gotham XBMC. I also just upgrade my xbmc to 13.2 beta version and it has been running pretty smooth and very snappy.
I tried it and it fails.
Icons issue is solved after downloading gotham 13.2 beta. RC issue still there. I don't think that the RC issue is coming from Gotham. It is more of a ROM issue.
There are currently 2103 users online. 1 members and 2102 guests.
