Supported SD cards for this box
Hi everyone,Do these boxes support class 10 uhs 1 SD cards? And what is the maximum supported size of card you can use?I need to purchase a new SD card as I have managed to lose my old one. I'd like one much faster than my old 20mb/second basic card.Would this be compatible? http://www.futureshop.ca/en-ca/produ...8208df9ba9en02 -
Guest
Get a cheap one from ****, can get micro sd which sometimes comes with full sd size adapter which is a dollar anyway, so can use in other devices. You don't need class 10, buffering works. Any capacity up to 64gb works, get a Cheap 16 or 32gb.
Originally posted by ftv View PostHi everyone,Do these boxes support class 10 uhs 1 SD cards? And what is the maximum supported size of card you can use?I need to purchase a new SD card as I have managed to lose my old one. I'd like one much faster than my old 20mb/second basic card.Would this be compatible? http://www.futureshop.ca/en-ca/produ...8208df9ba9en02
Guest
expensive quality sd cards with class 10 speed are good for FHD (1920x1080) or above or 4k video cameras, specially if indexing lots of takes as typical usage and/or editing.
Originally posted by washere View PostGet a cheap one from ****, can get micro sd which sometimes comes with full sd size adapter which is a dollar anyway, so can use in other devices. You don't need class 10, buffering works. Any capacity up to 64gb works, get a Cheap 16 or 32gb.
Guest
Originally posted by rlaursen View Posti thought the max supported was 32GB?
An expensive quality made class 10 card is unnecessary for this box.
Originally posted by rlaursen View Postcan anyone try a 64GB card and let us know if the EM8 supports this size?
read and write 64g ok
Using 1.8b em8 Square
Rob
There are currently 2866 users online. 2 members and 2864 guests.
