Tronsmart s89 hdmi to dvi not working
I have tried DVI adapter to my old PC LCD. It works fine for me.
Originally posted by zaus1978 View Postiv tired every thing i can think of iv updated my firmware using your version and stock. used two dvi to hdmi addapters but i still get no picture. but it does work on my tv. is their anything else i should try
I just tested on 2. One that supports 2300x1600 and one that supports 1800x1200. The one that supports 2300x1600 works., The one that supports less than 1920x1080 gives me a "sync" error and will not work.
So your monitor needs to support minimum of 1920x1080. If it is less than that, not going to work!
Now, what you might do is flash my 720P patch on my ROM. This lowers the resolution "correctly" and may work... But this is just a guess.. I did not try it myself on my 1800x1200 monitor. If that does not work then your monitor simply cannot support the rez and refresh rate. Sorry.
Originally posted by Finless View PostWhat is the native resolution of your DVI monitor?
my monitor does support 1920x1080p60Hz, but my Beelink S82 can't work through HDMI->DVI adapter.
I tried 2 different adapters. I also bought another 2 adapters to try - will do this soon.
Also I have minix X8h - and it's working fine with one of 2 adapters.
There are currently 1784 users online. 1 members and 1783 guests.
