This is the new custom rom for Tronsmart Vega s89 Series.All credit to Leolas and other developer, thanks again for your hard working to make this little things rock!
changelog:
- Rooted with last Supersu Version, Init.d activated, and last complete Busybox binary installed.
- Recovery with adb support and complete busybox installed.
- Stock ir remote works in recovery.
- Kernel build with NTFS (rw), HFS (Mac filesystem), NFS, CIFS support.
- XBox and PS3 Support Build in kernel.
- Multiuser& Screen lock support enabled in the SDK.
- Clear recent Task enabled in the SDK.
- Google Apps updated to last Version.
- Preinstalled Apps: Terminal Emulator; Reboot apk; Es File Explorer, Chrome, Adaptative Rotate Lock, Xbmc 13.1 (by Oman), MX Player and youtube. (Most of them like user so they can be uninstalled easy).
- Some tweaks and things I cant remember actually
Firmware Download link
Firmware update instruction:
Download the zip; copy it to a usb memory or external Microsd card; Boot in recovery, select wipe data/factory reset (it will erase your internal sdcard and apps); and select Install from EXT, select the zip file and wait until it finish, then select in recovery reboot.
Once the ROM is installed, after first boot it will reboot the Box to properly installation of some configurations, so wait a couple of minutes in the welcome screen and it will reboot automatically.
Source from: http://bit.ly/1tUiLGx
