Patched firmware for New MK808B fixes stuttering and fully rooted.
The stutter is gone.
For most, unless pointed out will not see the stutter, I didn`t at first.
You`d be surprised at how many TV boxes have this stutter.
Even the Minix X7 had this frame skipping until it was fixed.
Thanks for sharing.
Something else about this new MK808B, with the color balance not right, skin tone looks off, peoples skin look a bit reddish a bit like sun burn.Last edited by Johnoo; 19 July 2014, 14:38.
I'm using the latest oman build of xbmc and I've also used the latest nightly build of xbmc as well and there is absolutely not stuttering issue. One thing to get the least frame skipping with high bitrate 1080p movies is to disable all other forms of acceleration in xbmc except for libstagefright. So, only keep libstagefright checked, uncheck all the others.
There are currently 2053 users online. 0 members and 2053 guests.
