MX TV box will not open in a different location
Hi all, I can run Mashup, from my own wifi, everything opening, but i have tried to use the box a few miles away, connecting to there wifi, putting in the correct key etc, but Mashup will not open anything. What have missed to do in the settings. Thank you. Robert.Tags: None
hi,
could be there router..
-is blocking ads ( metadata/filhosts )
-firewall rule is blocking incoming conn
-iptv or port forwarding might be need/enabled
my adv...Check the log of there router
or perhaps.. there provider is blocking streams (like most uni/schools/public-hotspots)
try using a proxy (under addon/settings)
or try finding another near by (open) hotspot
easy solution...just invite your friends/fam to your home
There are currently 2363 users online. 0 members and 2363 guests.
