What is better? G-Box Midnight MX2 or Android Mini PC RK3188
    Hey guys I'm on the wall between both of these devices. First off here are links for your reference:
    MX2
    G-Box Midnight MX2 Amazon Link
    RK3188
    Specs for RK3188
    While on paper the RK3188 appears to have better specs (more RAM, Quad core, and cheaper) my only concern is that the MX2 appears to have a ton more users using it exclusively for XBMC (The main thing I'm going to use on either devices) and they all are enjoying it thoroughly. So I'm not sure if the MX2 has been optimized to work great with XBMC over the RK3188 or if it is simply that more people use it because it already has XBMC preinstalled on it.
    As a note to people I am computer savvy, I work in an IT department. I have dealt with XBMC in the past so having to setup the RK3188 is not a factor (but I wouldn't mind paying the extra $20 if the MX2 is truly the better device). And playing games on the Android interface is not a requirement, it's bonus points if anything.
    So let me know about your opinions, I'm hopefully buying one (or hell maybe even both) of these within the next couple weeks.
    Mx box M6 has an AMLOGIC CPU that alone is the enough reason to buy it if you are after xbmc but you can go for the newer S802 boxes for the better performance...
