Need some help here NEWBIE! M8 Amlogic S802 Quad Core Android 4.4 Smart TV
Ok so I bought a M8 Amlogic S802 Quad Core Android 4.4 Smart TV Box 4K HDMI FULLY LOADED XBMC..... It says FULLY LOADED XBMC....but it also says that the box is unopened! So can someone please direct me to the section I need to go to read about these units and how to setup...where do I start? Tell me what you have on yours and how good it works! Thanks!Tags: None
Configure your tv box
First configure your internet wired o wireless in your M8, then go to XBMC and run for first time and install the basic plugins addons.Then I recommend follow the steps to install the fusion installer or the mashup installer. You can find how to do it searching google or youtube. If you are a spanish speaker I can help to install some special spanish addons.
Ok
Originally posted by hearol99 View PostFirst configure your internet wired o wireless in your M8, then go to XBMC and run for first time and install the basic plugins addons.Then I recommend follow the steps to install the fusion installer or the mashup installer. You can find how to do it searching google or youtube. If you are a spanish speaker I can help to install some special spanish addons.
Thanks...
I can help
[QUOTE=RECO6901;206591]So I don't have to root it or flash a different software to get the added movie channels or Live PPV etc?
Look up Supa Charged iOS on youtube and look up Armada M8 root and he will guide you through the process along with show you where to download the root. Definitely root the device and then look for Oman version of XBMC for S802 and put it on an SD card and remove the old XBMC in settings under apps and then install the new Oman version off of the SD card. The only tools you will need is a toothpick and an SD card. If you have any other questions just ask.
Thanks!!!
[QUOTE=NIPSZX;206718]Originally posted by RECO6901 View PostSo I don't have to root it or flash a different software to get the added movie channels or Live PPV etc?
That's the reply I was looking for! Thanks for all the help!
Armada Mach 8 Firmware update?
Ok...something missing
thanks...
The firmware is the root
[QUOTE=RECO6901;206591] I followed the directions....installed mashedup....and fusion...under fusion I didn't see the folder...most popular...so how do I install project free tv etc?
thanks...
Install the xbmchub repo by going to settings and file manager then type in Fusion.xbmchub.com
After that go to settings and add as a zip file
Then install the config wizard / add-on installer
Then you can install add-on simplified
After going to the config wizard then press 1-channel update and android config
It will give you the best version of the add ons you want
There are currently 1645 users online. 7 members and 1638 guests.
