help with (pc) mouse clicks not "touching" the screen in some games
    hi all
    i'm using finless 1.8 on a tronsmart s89-h (running great so thanks Bob for the hard work)
    i have noticed a common "issue/problem" with my box...
    this same issue also exists on all my other android devices when i use a pc mouse
    (inew i6000, JXD 7800B and brandless RK3188 tv box)
    so i think it's something that everybody has experienced if you are using a pc mouse to play some games
    (i have tested 2 different types of mouse and also a RII K12)
    this is my issue/problem
    in some games the mouse cursor does not respond to touching the screen (when i left click with the pc mouse) and others run very well so i was wondering:
    (angy birds epic is an example of a not working game)
    is there maybe a way to change te size of the touched area when i left click on the screen
    (the idea i have is to possibly emulate a bigger size finger touching the screen)
    maybe increase the size of the "touch dot" when you click a mouse...
    Is this even possible?
    is so could somebody explain how to change the size of the "touch dot"...
    thanks in advance
    I think that the issue is in the game itself.
    You can use Tincore Keymapper and create a profile for a game (https://play.google.com/store/apps/d...eymapper&hl=sk).
    Just setup the correct function for mouse movement and buttons (there are many videos on youtube how to setup the app).
    Tronsmart s89 Elite - Finless 2.1 ROM
      solved my own problem
      i was able to solve my own problem...
      so YAY me!!!
      i used tincore keymapper
      i made this profile on my homescreen (i use apex launcher)
      and made my left mouse button (m0) in a "touch hybrid pointer"
      and with the mouse movement (relative r0) i did the same "move hybrid pointer"
      the onscreen pointer changed into a square and all the games that didn't work with a regular mouse now work... (now android "sees" or better registers a touch on the screen instead of a normal mouse click)
      Last edited by alucard369; 25 July 2014, 19:43. Reason: adding screenshot and typo's
