If you have my 1.5a system.img loaded then you have onandroid. Download from the market Terminal Emulator. Run it. At the prompt in terminal type su.
then type onandroid.
It will do a full CWM backup to internal sdcard from the OS. Totally cool!
Then copy that backup to external sdcard. Now you can do a boot level CWM restore from sdcard (external).
As for dual partitions etc... YES... I have a work around for this but it requires a major change to vold.fstab to tell Android to mount it as ext4 instead of FAT32. Not sure people will be able to deal with this major a change since Windows cannot read EXT4 without 3rd party software. I just do not want to make this major of a change to a ROM unless people really want it.
