This is for RC11 and works fine on my beta 7 with the Finless tweaker. I made the kl file myself. Make sure you change the perms and restart the box for it to take effect.
You can use https://github.com/chrisboyle/keytest/downloads to check the keypresses map to the file and run cat /proc/bus/input/devices from a terminal app to find out the vendor and product of your remote
I'm interested in remapping all of my various remotes to work on my minix x7. Can you make a video to show how to do this? Or maybe a step by step guide. It sound difficult form a non coder or noob point of view. Can you make more then one file in the android folder for all your remotes? Each remote has its own file?
Not sure if I can do a video but I'll see what I can do to help with screenshots. It's pretty easy. I'm not a coder, and I've done the same for my MK908ii. You can indeed make one file per remote.
