Tronsmart MK908II currently suggested ROM/Kernel
Hi Manovel,
I recently brought a MK908II, another user asked the same question & if you want to read my responce checkout the thread here :
Only thing I´d add to whats written there is I changed kernel to the 1.8ghz 720P with stock ram and stock gpu, pushing 20000 in antutu and shes still fairly cool, other than the wait after boot, this is not a bad device, runs xbmc 1080P content no problem, rom is really stable.
i have the same stick, MK908II, best rom ive found is Bobs kitkat 2.0 for the A928 combined with D33 kernel with a nice overclock, 1608/720/600, my stick has a T chip, you need to use v3 ap6210 kernel as the rom is based on beta source.
http://www.freaktab.com/showthread.p...All-(well-most!)
Originally posted by marko33 View Posti have the same stick, MK908II, best rom ive found is Bobs kitkat 2.0 for the A928 combined with D33 kernel with a nice overclock, 1608/720/600, my stick has a T chip, you need to use v3 ap6210 kernel as the rom is based on beta source.http://www.freaktab.com/showthread.p...All-(well-most!)http://www.freaktab.com/showthread.p...inless-2-0-ROM
Hi,my chip is not T;
I tried your suggested ROM/Kernel, but was remaining stuck at the booting image.
I am running now:
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
with d33 v3 ap6210 kernel
I got good performances and good video playback with plex and youtube.
However, using a TV streaming app (zattoo) the playback is somehow strange, slowing down in some moments and speeding up later. Did somebody experience something like that?
manovel
zattoo issue
I am running now:
manovel
don't know we mean the same issue with zattoo: while streaming (hd) it switchs from hi to low resolution?! this problem was also with the original tronsmart firmware and other. have had this also on a "older" mk808.
but i think i solved this problem on the mk908ii with this kitkat rom:
i've installed the first version in the first post of veclinux (there are also higher versions with 1080). i running the mk908ii now on 720 resolution (btw: zattoo streams maximum 720).
and surprise surprise: zattoo streams smooth and stable, with no hi/low "switching".
xbmc i will try later, but it seems working fine too.
greets from switzerland to switzerland
I followed your suggestion and I am now able to use Zattoo streaming flawlessy.
I do not experience slow-downs/speed-ups and the audio/video is synchronized.
I did not try XBMC, but I am less interested in that...
Manovel
MK908II 25-07-2014 firmware?
Hi
Has anyone tested newest Stock firmware for MK908II?
Tronsmart_MK908II_4.2_20140725.zip
I have currently stock 205j2 17-12-2013 version firmware on my MK908II. I could not find any release notes about that new firmwareI couldn't download it, tried two times and download was interrupted on both times
It would be nice to know is that beta or stable release, and what they have been updated. I could not find any info about this.
I was wondering the same, just got my MK908II yesterday, seems to work well so far on stock FW but has trouble loading flash. gonna try finless 2.0 w/d33 later today.
There are currently 2127 users online. 1 members and 2126 guests.
