Problems watching hd movies on Xbmc
    It's driving me crazy, almost 90% of the time and at around the 10 minute mark, I loose the picture (freeze)but not the sound. Then if I restart the movie works fine until that same time. The I look for another source SD and it works ok. Any one else with same problem or possible solutions. Is my video settings (how come only around 10 minutes) or is it the source( switched from NavyX to IceFilms same problem)?
    I am using X7 with the latest Firmware.
    its the source mate ... Same thing happened to me ...
      But why always at 10 minutes?
        who knows it was same minute (10) but with a complete different device...(s802-M8)
          It's the Buffer for that Server
          If your movie cuts out it is potentially due to the buffer. The source server may be to slow to sustain the stream. It happens more and more with the 3rd party repositories as they can't handle the ever increasing number of people accessing their private and/or "pay-per-use" servers.
            just use this xbmc and all goes fine ;D
            --->>> http://www.freak-tab.de/wasser/wasser-xbmc-v1.3.apk
            inside this xbmc there is a fix for this "10-minutes" problem
            just install and have fun ^^
            original post here -->> http://www.freaktab.com/showthread.p...l=1#post206424
              Try the new SPMC it fixes the 10 min bug......................http://spmc.semperpax.com/
              cheers,
              Vec
                cheers,
                Vec
                Thanks but how can I install it? got it sorry my mistake installed apk . thanks
                  As strange as it may sound, if you have an advanced settings xml of any kind, try deleting it or renaming it to backup or something, then re-start xbmc and see if the bug persists - advanced xml settings can cause these kind's of issues.
                  Kind regards from the Ultimate XBMC team (here to help).
                  Team UX
                  http://www.ultimatexbmc.com/
                  http://www.freaktab.com/showthread.p...-ULTIMATE-XBMC
