Which ROM should I use on my MK809 III B(to get wifi working)
    Hello.
    I tried to install new firmware on my mk809III B which I bought 1 month ago here -> http://www.dx.com/p/mk809-iii-b-quad...6#.U9jVZ2MgbIU .
    I tried 2 firwares:
    - http://www.freaktab.com/showthread.p...4-4-2-*Update*
    - http://www.freaktab.com/showthread.p...Fi-Version-0-9
    but on both wifi didnt work. All the time "Turning wifi on.." .
    I tried to check wifi model with dmesg but didn't found any model name.
    Open your stick.
    Make a sharp and detailed photo of your board.
    Upload it and post the link (e.g. dropbox, gdrive, etc.)
    Kind regards Snuffy
      Originally posted by eve_Snuffy View Post
      Open your stick.
      The quality would be terrible so I post here all I could read.
      rockchip rk3188-t
      ccau33gc 1409
      NANYA 1335
      active 8846QM gd363
      xzh_tv03_1R2? 20131119
      D809 8G
      XT140419 2G
      XT2014041815R 04.22
      ite it6612fn
      1401-BXG
      AC0Q7C
      and last thing propably wifi chip
      ??8723?
      But i have bigger problem now. Recovery button seems to doesn't work after 2-3 firmware tested. I hold it when plugin cable and nothing. Last firmware stuck on loading screen - Google Tv splash. After I tried 1 software with diffrent kernel.
      Is there any way I can fix now ?
      Rom Flash Tool recognize usb cable after some time as mass storage but switch button doesn't make anything.
      System I use is Windows 7 64bit.
        Open your stick.
        Hello, I have this device called "MK809 III B" similar to the first post bought in dealextreme too.
        The chips are:
        RK3188, mt5931sa and mt6622n.
        I want to fix the frameskipping issue, which rom should I install??
        Thanks.
          I'm using Neomode Custom Rom MK809III MTK WiFi Version 0.9, with overclocked gpu...working nice, no skipping but it's Android 4.2.2 and not kit-kat... Couldn't find working kit-kat for MTK chipset
          rgds,
          viliam
