How to set correct time?
    I must be missing something because I can't get the correct time on the home screen. I went into the clock settings and picked the correct time zone. The home time in the clock setting is correct, however, on the home screen and in XBMC it is 3 hours off. How do I correct this? I am using beta 007 with Finless's tweaker.
    Thanks,
    Gadget
    At XBMC maybe this helps
    RK3288 Devices
    - Overview BOX (LINK !)
      Originally posted by no_spam_for_me View Post
      q
      Thank you for the response. This only changes the format of the time for me(ie 1:00pm/13:00 hrs).
        Set manual timezone, I live in Sweden an usually need to set mine manually to have the right time.
        Sent from my Nexus 4 using Tapatalk
          I did same as piere i also live in sweden! and never got the time right with the auto setting.
          [img=http://imagizer.imageshack.com/img537/6746/zABbhG.jpg]
