I've got a new M8 and having some issues with it. Basically it cannot access internet at full speed, both on WiFi and Ethernet. I've tried all the available firmwares but, having the same issue. I have 4 Mb connection and all other devices can access it at full speed.
so decided to do some testing with Network & CPU overlays.. Below is what i found.
Accessing content on LAN
I tried steaming various files over the LAN accessing it from my PC and it works fine without any issues.
When the video player starts, you get a burst of download speed which goes up to 2.3Mbps and that it stay over 1 Mbps giving smooth picture playback.
Main CPU usage is done by the movie player in use.
Accessing content over the internet
When accessing internet based content, you get a burst of download speed going up to 350kbps and than it hover round 80kbps. This causes buffering issue.
Main CPU usage used is caused by two processes named "System_server" & "Surfaceflinger" respectively.
when i try to kill this processes, it causes the box to reboot.
what do you guys think?
