hello,
i have a mk908ii, it uses the t010 rom, with d33 4.1 kernel, and a 2gb parameter file.
if i go to options > display > screen > screen scale and set it up to full screen after a restart it will reset to a smaller image.
can i edit a file like build.prop or some thing like that.
