my CS918 is dead
    my CS918 is dead
    hi can someone help me?today i tried to change the firmware to my andrid box CS918 but after trying give me an error and the box now wont power on.any suggests?
    Totally dead? No LED on?
    Maybe try another 5V PSU...
    If LED blue ore red maybe have a look at
    RK3288 Devices
    - Overview BOX (LINK !)
      yes totaly dead no lights on and the adapter is good.
        hmmmm, but if it's totally dead (no lights on) you can try to do 'MaskRom' mode, because I think it can't get more worse...
        RK3288 Devices
          Or..
          Try powering the unit.. using the usb2micro usb cable
          -like by using a external powered usb hub or adaptor
          To rule-out a broken/blown dc port fuse
          Just a thought..
            Re: my CS918 is dead
            This is the cs918b that is what it says on the back. I need the firmware for it either 4.2.2 or 4.4 if anyone has it can you send it to me thanks. I installed a version of 4.4 but I can't get wifi or Lan can someone help me
              @no_spam_for_me
              hi i tried to do it with clip on nano chip.i start the
              RKBatchTool_v1.7 and the light came blue but for a few seconds.can you help me what is wrong?
              and sorry for my bad english.
                About what one of your boxes do we talk?
                1. This one which is totally dead?
                2. Or the one which stops booting up at android logo (http://www.freaktab.com/showthread.p...128#post211128) ?
                And what means "blue but for a few seconds"?
                3. Do the PC lost the connection after some seconds?
                4. Or only the RKBatchTool?
                I don't know if you can / have to release the shorting of the oins after it is recognize as MaskRom mode OR you have to short the pins also during the Erase and/or Flash process (as I wrote, I never use it)....
                RK3288 Devices
                  i am talking about the dead one.but the other one i did it. now its working.
                  the problem is with the dead one when i try to erase the nand its tell me this ERROR:MaskRom must choose loader for erasing..what can i do?
                    Nice to hear, that the one which stopped at boot up NOW works
                    'ERROR: MaskRom must choose loader for erasing'
                    Maybe if you use the RKAndroidTool to erase the NAND you have to place one of the 'RK3188xxxx' at the same directory
                    and maybe you must edit the config of the RKAndroidTool to use it (activating it via check it at the first column)
                    Originally posted by no_spam_for_me View Post
                    I prefer the RKAndroidTool because I'm able to flash separate parts.
                    To use it, you need at minimum the bootloader (RK3188Loader(L)_V1.2x.bin), (the parameter file) and 1 image file (misc, boot, kernel or...) that you want to flash.
                    The first column is for selecting/activating what you want to use to flash.
                    The second column called "Address" contains the value depends of the parameter file.
                    The third column called "Name" contains the value depends of the parameter file.
                    And the last column called "Path" contains the whole filename.
                    These whole settings can be save or load by using right mouse button at one of the rows, and add new rows also...
                    First row have to contains the bootloader (RK3188Loader(L)_V1.2x.bin) at address 0x00000000 with Name=Loader . Don't ask me why, I couldn't get an answer, but it seems it is a must to have (Perhaps after "EraseIDB" (nand) for temporary use in ram??? Because the parameter file have the same address as the bootloader, but I've also seen a picture at the internet where the bootloader hasn't any address???) ...
                    I think you can ignore the parameter file and the image file...
                    RK3288 Devices
                      now ok i did it i wake it up the blue light comes on.now the problem is the firmware i put the wesser new one but its not working good like remote wifi etc.can you tell me wich is the best firmware i can use?
                      i have this box CS918 HLSX_X6_V12
                        Is it printed at the PCB?
                        Here you find HLSX_X6_V12
                        BUT the picture seems to be wrong because it's printed as LS_X6_V12
                        and I can't find any information for HLSX_X6_V12 ...
                        But for LS_X6_V12:
                        and via google http://www.google.de/search?q=LS_X6_V12
                        RK3288 Devices
                          hi now i did this box working very good.the only problem that i have is not recognaise the storage nand flash i tried to format it,but its tell me storage damage.can someone help me to solve this?
                            ive got one of these
                            ive got a box like this what i need is the image file for android 4.2 to load with RKBatch tool can anyone help!
