SuperSU Wonky ?
    SuperSU Wonky ?
    So I have been running finless 1.8 for a while now along with XBMC launcher and everything was working great. However, a recent update in XBMC Launcher prompted me to try a fresh XBMC 14.x build but I wasnt happy with it so I reverted back to my old 14.x build. Anyways, since then, XBMC, when started with XBMC launcher seems unable to acquire root. If I go to apps -> SuperSU, SuperSU will complain of 'SU Binary not found'... eventually, if I kill XBMC and restart it, it seems to work better (and acquire root).
    Any Ideas why this might be happening ?
    No idea why, but if you want to use it again, reroot it
    RK3288 Devices
    - Overview BOX (LINK !)
      I'll try to re-root but the device IS rooted. It's just that when xbmc is launched at startup, it's not. When nova launder is used or xbmc is restarted, root works.
        Setup SuperSu to grant root automatically, it might help.
          OK, the problem is, that the startup is too fast... the demon need some more time to enable/start su...
          RK3288 Devices
            Correct. After a reboot WAIT about 30 seconds for the system to stabilize and the SU daemon to get running. These boxes are a little slow about finishing background boot tasks even though the launcher is up and running.
              Thanks for the info.. Just a shame because it seemed to be working at one point
                Would it make sense to set the needed permissions using the init.d ? Perhaps something that could be baked in?
                  2.04 has fixed allot of bugs
                  19.08.2014 - v2.04 - BETA
                  - Fix bug where grant as default access still showed a prompt
                  - Added reboot button in dialog after binary update
                  - Added tapjacking protection - may cause issues with screen dimming apps!
                  - Added removing Team Venom SU
                  - Added new dalvik-cache paths to clear on package maintenance
                  07.08.2014 - v2.03 - BETA
                  - Fix exitcode sometimes being wrong when full content logging is enabled
                  - Fix automatic OTA survival
                  27.07.2014 - v2.02 - RELEASE NOTES
                  - Fix internal zygote crashes on L preview
                  - Fix issues with L preview when SELinux set to permissive
                  - Fix un/reinstall of apps causing a UID mismatch, causing auto-deny
                  - Added notification telling user when binary needs to be updated
                  - Updated language files
                  30.06.2014 - v2.01 - RELEASE NOTES
                  - Update normal, TWRP/CWM, and CF-Auto-Root installers for changes in "L" preview (no binary update)
                  Bugs are Sons of Glitches!
                  JustMe
