Identify what device is this?
    Hi guys, can someone tell me what my device is based on the picture? It was labelled as a CS918 when i bought it but i read somewhere that CS918 does not have BT. Mine has wifi and BT.
    Anyway, this device has problem trying to connect to vpn (im using droidvpn but cant find any from thr tun.ko). Can anyone assist?
    On google market is a app called, tun.ko installer
    That should resolve the problem..
    Note.. this app requires Root access
    To id.. your unit and info finder
    Goodluck
      Fantastic and thanks for the fast reply! Found the device from your list just now. Will try to root the device later. I didnt know root is needed for tun.ko to work.
        not to necro-post but I couldn't find anywhere to create a new thread. I've had a similar issue to the above being that I cannot identify the device, I don't own the laptop so these pictures are the only thing I have on the computer.
ID:	739754 ​​​​​​​ Click image for larger version
ID:	739752 ​​​​​​​ Click image for larger version
ID:	739753 ​​​​​​​ ​​​
