First I would like to thank FreakTab users for their donations. Up to know I have been a RK (RockChip) ROM maker. But I wanted hardware to learn other Architectures! Donations from FreakTab member made that happen. Last week I got the Ramos W13Pro 8" Dual Core tab. THis is based on AMLogic chipset.
I spent the last few days learning as much as I could about this ROM architecture. WHICH is very different than RockChip! The thing I set my mind on was how to make a rooted ROM without first rooting my tablet using APPs or tools! Well I was successful.... I enjoyed very much learning this. But I have to say just like RK29 when I first started doing this, there is NOT a lot of good info out there! So like my first root on RK29, I had to learn all this the hard way!
Again doing it this way WAS AN INVALUABLE LEARNING EXPERIENCE! I now think I could make ROMs for just about any AMLogic tablet out there including models I do not have!
My next goal is to learn how to make CWM for AMlogic devices. Let me tell you, unlike Rockchip, I do believe you can totally BRICK an AMLogic device.
As for what I know in a few days, it all uses a kernel and a recovery to flash. There ARE no PC based flash tools to recovery from a BAD brick. If there are, I have not read, found, or learned about them yet!
OK enough babbling by me........ Here is my W13Pro ROM that I have done a lot to make better.
PLEASE READ THE README.TXT IN THE ROM KIT DOWNLOAD FOR FULL INSTRUCTIONS!
Features:
1) Fully Rooted! Not semi-rooted! This includes /system being mounted as Read/Write by default.
It is using the latest ChainDD Superuser.apk and SU binary BUILT IN!
2) Full Google Play store! I have patched the files to give full access to the Play Store.
This means things like Google Chrome, etc show up now when you login!
BUT... this does not mean all will work! I have not modified build.prop.
You can if you wish to get even more compatability....
3) It is debloated of bloat apps! I left only what I felt was needed.
4) Some tweaks to allow full ADB access(root) and debugging and some other fixes I normally do on all ROMs.
5) App Injector. While it is not installed it is in the ROM kit.
I have supplied some APPs that on this date would not work when downloaded from Google Play!
This includes a version of Youtube that will work on this ROM along with some other
Google Apps that either do not show up or wont run on this ROM.
Here is the ROM download:
ROM -> Ramos W13Pro - Finless ROM 1.2 - Full Root and Full Gplay (150 megs)
And here is my Flash11 Patch kit. This fixes the Stock ROM as well as my ROM for Flash 11 support. Copy onto sdcard and use the APP to install update!
Patch -> Ramos W13Pro - FLash 11 patcher (5 megs)
Enjoy,
_____________________________
Damo - Forum Moderator
Please Click the Donate Button
PS
If you are having trouble with the above link when using Tapatalk than here is the email link for donations below
https://www.paypal.com/cgi-bin/websc...=ZYCM4NZ4J6F3G
Thank You
