What I do:
1. hold power button, then plug into windows 7 pc.
2. PC says 'bedonk' and device is detected.
3. as the drivers have been installed correctly, it's detected
4. RKAndroidTool says 'No Found RKAndroid rock usb'
what I've tried:
- 6 different USB ports in my pc
- 3 different USB cables
- USB Debugging is turned off
- Mass Storage is selected
- RKAndroidTool 1.37 and RKBatchTool
- Rockchip driver 3.5 and 3.7
- type 'su' and 'reboot bootloader'
what DOES work:
- device works fine, can connect it in a HDMI port and play around
- connect it to PC and see it as a mass storage drive, able to transfer files
- Windows 7 sees the device, says that it's installed correctly
- I was able to flash ROM's before and did so 3 times before
Help....
I'm stuck, can't find anything new on google or my own mind
