strange behavior
strange behavior
I turned on the tab today from sleep and it rebooted. Then there was a screen saying encryption unsuccessful and it did a factory reset! I didn't encrypt anything, think it might be a virus that slipped by Avast? had to redownload superuser to get root explorer to work, going to reinstall avast and check for viruses next. WTF!Tags: None
no viruses. searching the net, this is a cross platform issue with a common factor of ICS!
I'm going to power down more often, thinking it might be a lot of vm progs trying to access data coming out of sleep mode at the same time.
The sites I saw mentioned that you should not press the reset button that appears with the error message but power off to hard reboot a few times instead. That didn't work for me. waiting for system update.........?like that will happen.
There are currently 2341 users online. 0 members and 2341 guests.
