Density XBMC Themes
    Density XBMC Themes
    These past few days I've been working on creating simple, yet very powerful themes for XBMC. I called them Density, because visually they're small (3 main menus), but contain everything you'll ever need on XBMC.
    The theme focuses on simplicity. It has 3 sections; Movies, TV Shows and Live TV, each of which only have what you NEED, and aren't cluttered with many addons and shortcuts you'll never use.
    The Live TV section has 2 main features; the Paid Sports Services folder (containing all the paid sports addons if you have a subscription), and the Free Sports Streams folder (containing a list of my hand picked sports streaming sites/ playlists from multiple addons)
    It's perfect for anyone who's never used XBMC before, as everything is as straightforward as it possibly can be, and I've even created a set of instructions.
    Currently I have 5 versions, but I'm working on creating more. They are:
    Density RED:
    Download
    Density BLUE:
    Download
    Density GREEN:
    Download
    Density Nox:
    Download
    Density Confluence:
    Download
    Instructions on how to use/ amend the themes can be found here
    Don't download on Chrome
    It'll give you a malicious content warning halfway through. (It's not malicious, but for some reason Chrome thinks it is)
    To install, SSH into your device, and replace the contents of the XBMC folder. This is located:
    Android Android/data/org.xbmc.xbmc/files/.xbmc/
    iOS /private/var/mobile/Library/Preferences/XBMC/
    Linux ~/.xbmc/
    Mac OS X /Users/<your_user_name>/Library/Application Support/XBMC/
    OpenELEC /storage/.xbmc/
    Windows Users\<your_user_name>\AppData\Roaming\XBMC\
    Installing on Linux/OpenELEC
    Since changing the guisettings requires XBMC to be closed, OpenELEC and Linux users must take these steps:
    1) SSH using putty to the IP Address of your media centre - Username: root, Password: openelec/letmein
    2) Type touch /var/lock/xbmc.disabled and then press enter
    3) Type killall -9 xbmc.bin and then press enter - Your media center machine should now go blank
    4) Connect to your machine using WinSCP and copy the contents from the theme into the XBMC folder on your device
    5) Go back to putty window and type rm /var/lock/xbmc.disabled
    6) Type reboot
    If you have any feedback/ requests, let me know.
    Enjoy!
    Interesting will try thanks
    Guess not they are all dead
      They all look nice. Can you easily edit the sub-menus?
