Question about my android tv box
    Hello everybody
    I was hoping someone could help me.
    Yesterday,I got this android tv box https://www.youtube.com/watch?v=gZdovfeRk0k
    So I was wondering if anyone knows what model it is and how to root it.
    Thanks in advance
    Its a cs918/k-r42/mk888 or t-r42.. this tvbox is sold under many names
    -note there are about 26 pcb/motherboard versions/revisions, and the only way to see what you have..is to open the unit
    --http://www.freaktab.com/showthread.p...s918-and-T-r42
    In short..
    You never really know.. what you get
    Only a few sites like geekbuying.. sometimes state what pcb you might get..
    Oops.. forgot
    Root.. there is a howto on blog.geekbuying.com... and vids on youtube
    Short version..
    Download moborobo and tpsarky from rockchip.nl/downloads
    Connect your unit to usb2.0 port On your pc..using usb2micro-usb cable
    Install moborobo.. quit app... run tpsarky -follow the steps as stated... 3 unit reboots and you have root
    Goodluck
      thanks
      when i open it,where i need to look to find out which model it is?
      and do you know anything about rooting for boxes similar to this one
      do i just need to download some tool and flash a custom rom or something else?
      or maybe there is just root for rom which i already have(i would prefer that)
      oh now i see that you already told me about root thanks
        i just have a problem
        moborobo gets stuck at 99% when trying to install driver :/
        it finally finished and said that driver was not found
        i have downloaded some drivers manually but they have no exe file...how do i install them?
        EDIT: i did it at the end,thanks
