Gamepad for m8
Originally posted by sutty86 View PostReceived box today running finless 1.7 already installed is it worth sticking on 1.8?
Managed to find an old generic ps2 USB controller or ps3.
How can I sync this with m8?
Cheers
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postsilly question have you turned on BT and installed : http://www.freaktab.com/showthread.p...ort-ZIP-update
JustMe
Originally posted by sutty86 View PostCheap crappy controller it's going back buy cheap buy twice my motto
So should I get wired official xbox or wireless ps3 pad
(so you have to use it via USB...)
It seams to be a good idea to order a xbox 360 + pc module OR the tronsmart mars g01
One way to play games in Android TV Box with a gamepad is to use a Sony Playstation 3 Controller with Sixaxis Controller app. It can work, but you need a
last I have ordered but at the way at the moment... (have a look at the minx x8 sub-forum)RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostWith ps3 bt at the moment the sixaxis app doesn't work because of a bt stack problem...
Hi, I use a Wamo Bt Controller, same as the G910 and play asphalt8 very nicely on my M8. I'm on the finless 1.8 rom and followed the tutorial of geekbuying(will post link below). I had to install the Wamo/G910 gameclient and Openpad union app(think that handles the auto pairing). Now all I do if I wanna play a game is to go into gameclient and press "home" button once (after first initial pair) and the controller is detected.
Note that certain games are supported out of the box.
Link to install guide:
G910 Bluetooth Game controller just get new firmware update, it make the controller reconnect directly once it auto power off. Here is the firmware download link: http://www.mediafire.com/?mq93o862cp60ob2 Here is the […]
Link to controller(look almost to bottom of page of some supported games):
China-1 Stock | Buy NEW G910 Wireless Bluetooth Gamepad Game Controller for Android TV BOX/Mini PC/Smartphone/Tablet PC + IOS supported online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
I have to add that the "Tincore" custom keymapper app is also having support the G910/Wamo:
Hope it helps
Originally posted by Phrozin View PostHi, I use a Wamo Bt Controller, same as the G910 and play asphalt8 very nicely on my M8. I'm on the finless 1.8 rom and followed the tutorial of geekbuying(will post link below). I had to install the Wamo/G910 gameclient and Openpad union app(think that handles the auto pairing). Now all I do if I wanna play a game is to go into gameclient and press "home" button once (after first initial pair) and the controller is detected.
Hope it helps
There are currently 2391 users online. 0 members and 2391 guests.
