Beelink S82/S82H/M8 & Tronsmart S89/S89H - Finless 1.9 ROM
    OK folks so the 108K4 came out a week ago.
    Sorry for the delay in getting this out but once again I was working on the X8 and the poor ENY M8 box that needs lots of help!
    It is also my Birthday week!
    About the same stuff I do to my ROMs but this time I did not have to do everything as Oman is now putting much of my patches in the stock ROM!
    But not everything as you can see below.
    ____________________________________
    This is based on the S82/S89 108K4 ROM.
    This is for the following devices:
    - Tronsmart S89 and S89-H
    - Beelink S82 and S82-H
    - Beelink M8 (black and red round box)
    This IS NOT for the ENY/Acemax EM8 square box!!!
    Features and release notes for my 1.9 ROM:
    1) 108K4 was no rooted from the factory!
    2) Updated Google framework core files. The ones in the stock ROM were out of date.
    On first boot NOTHING will need to be updated once you logon to Google Play.
    That is as of this date.
    3) Debloated of junk APPs and Google Apps you can get from Google Play.
    There was quite a few useless hidden apps in this KitKat release! Some of them did not even work.
    I did remove XBMC and other pre-install APPs as well. I like a CLEAN ROM that you the user can setup the way you want.
    Having APPs in /system leaves that junk in there forever (unless you delete them by hand with a root explorer).
    NOTE: The XBMC that came with 108K4 is in this ZIP package (Oman modified). Feel free to install it if you like.
    4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
    This time around due to updated security in 4.4, init.d was a lot harder to get working.
    Again I had to figure it out!
    5) I fixed the AOSP Launcher for several things:
    Removed the Google search bar by request.
    Added more than one screen for scrolling.
    Updated the dock icons to things more useful.
    Apps installed with Google Play will automatically be added to the home screen.
    I think you will like this launcher better
    6) Fix the bottom navigation bar.
    There was a bug in 108K in that on first boot the navigation bar is seen and it stuck there,
    even though in Mbox Settings it is set to hide the navigation bar!
    Before this fix you had to go into Mbox settings>screen and toggle hide bar off and back on to make it work.
    This is now fixed. It is hidden per the default Mbox settings on boot.
    7) By request I added the calendar APP and it now syncs with your Google account.
    8) By request the Contacts (People) now syncs with Google and your contact list.
    9) Xbox and PS3 added to the ROM now in 108K4 so it is there already.
    10) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
    I am spoofing a Samsung device (Nexus 10) that will show almost any APP as compatible.
    This should also allow Netflix HD but I have not tested it.
    Your device will show up in google play as Nexus 10 device not a S82/S89! Understand this please.
    I also left the original build.prop in the ROM called build.orig.
    If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
    Then rename build.orig to build.prop.
    Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
    Reboot! You should be back to showing up as a S82/S89.
    11) I added a reboot APP that will allow optional reboot options like reboot to recovery for easier updates.
    12) Added bonus! CPU fixer patches!
    In this ZIP is a CPU_fixer folder. These zips can be used to adjust your minimum CPU frequency and Governor.
    See the README.txt in that folder for an explanation and how to install them.
    13) Sorry folks. 720P patcher will not be provided this time!
    Why? Because the code has now drastically changed and I have not been able to make it work this time.
    I will continue to try and get the 720P patch working again.
    14) Carrier spoofs for better APP compatibility.
    15) The usual tweaks I do for better performance e.g. TCP buffers sizes, etc etc.
    16) Did a little "themeing" to the system. I hope you like it. I do
    ________________________________________________
    DO NOT just copy this download ZIP to SDcard and expect it to work!
    UNZIP it and read the README for instructions!
    If someone posts again it does work with a footer error I WILL KILL YOU
    Kidding... but man some people need to READ before jumping in head first!
    OK so here is the download!
    READ the README.TXT in the zip for instructions!
    ROM -> Tronsmart S89/S89H & Beelink S82/S82H/M8 - Finless ROM 1.9 (424 megs)
    Thanks bob for all the hard and time consuming work. Can this be flashed with the new twrp?
      happy birthday but too much booze i cant see any recovery image in this download
        Hey Bob does this ROM have the Kitkat onscreen keyboard?
          Happy Birthday Bob
            Ok a not so polite Q to the ROM-maker Bob with thoughts in mind that he worked with this pretty hard. Is this ROM really necessary if I have an working Finless 1.8 on my Vega 89?
            Should I just backup my downloaded apps if I try 1.9?
              NEW - Beelink S82/S82H/M8 & Tronsmart S89/S89H - Finless 1.9 ROM
              Happy Birthday! And thank you so much for this version. Keep the good work
                Just installed 1.6, runs great
                WOOPS, meant to say, JUST INSTALLED 1.8
                Three things that I noticed right away since version 1.6
                1- 802.11g works good now. Was way too weak before
                2- Mouse button on standard remote now works more smoothly.... it actually works now!
                3- Off button on remote allows to exit via Sleep mode or completely off.
                Runs nice and smooth....
                Thank you very much for your hard work.
                Dave
                  Works very nice with Orbsmart S82 from Germany. Thank you Bob.
                    finless can you please create an update.zip for fixed calendar and people apps to install in stock firmware?
                    thanks in advance
                      Happy birthday Bob i wish you healt and anything you desire,just flash your new rom to my measy b4a it took a little longer time to settle down from your previous 1.8 i 've used method 2 so far so good haven't been able to test it yet but first thing i do was to see if the 1080p 24hz works because in the 1.8 wasn't working for me but now presto it works with a little lag on my mouse but hey i am not complaining.
                      Will start to load my apps an see how it's going which i think will be great as always.
                      Thank you Bob and happy birthday
                        Happy B-Day
                        Happy happy happy birfday to you!
                          i dont get it there are only 2 files to put on a sd card bobs zip and factory parameter file there is no recovery file in the main zip ,downloaded 3 times now and its not there are you guys flashing with just these 2 files
                            Thanx Bob, Will tot as soon as I can
                              I use only the the rom and flash it with method 2
