Premium 7 Serial YF0511, Want google play / App Store Help
    Where do I go to root or do whatever for this serial number? I search and cant find anything for this one. More specifcally I really just want the Torque App on there.
    Nextbook 7 Premium YF0511 fix ...
    Hi Chaser5269,
    I have a Nextbook 7 Premium that was stuck in a boot loop on the pointing finger screen, the spinning icon would spin, then stop, then briefly a black screen, and back to the pointing finger. I figured the only way out was to upgrade the rom, but like you, I couldn't find anything for these serial numbers.
    Anyways, earlier today, I found this forum, and found Finless's custom roms for these tablets. Still nothing for YF0511, but I saw there is something for YF0811. There is a custom rom, rooted, with market, and further down the same page is a YF0811 stock rom. I downloaded the stock rom for starters, just hoping to get my tablet out of the boot loop, but not knowing if it would be fully compatible.
    It works!
    Wifi is working, sound, soft buttons. The Android version is the same (I have another tablet still on the original rom, also with serial number YF0511) 2.3.1, Kernel version 2.6.32.27, Gingerbread version 2.0.7, and Build number V2.0.7.GINGERBREAD.eng.root.20110526.062145_HW:2.0 .0
    So it would appear that these tablets have the same hardware from 0511 to 0811.
    I think if you were to try Finless's custom 0811 rom, you will have what you are looking for.
    Anyone who has the YF0511 should try the YF0811 roms if they are stuck, or just want to get root.
