**** only has one for old mkii.
LINUX MICRO SD WHERE TO BUY
Originally posted by moose m79 View PostAnyone know where I can purchase linux Ubuntu on micro SD ffo 802 mkiv new model?
If you want to spend money, make me a donation
Thanks lnuxuum
Originally posted by linuxium;21reply hy do you want to buy one when you can make one for free - see [URLhttp://www.freaktab.com/showthread.php?14827-Easiest-way-to-try-Linux[/URL]
Originally posted by moose m79 View PostI appreciate your relply I dont have a pc to mount image. Bluebonnet 101 is going to offer one for me on **** I hope.
CWM INSTALL
Linuxium,. Thank you for your help .Here is what I have Two 802 mkiiis 4.1.1, one works flawless one stuck in booot screen after I hit recovery thinking it was a reset.<br>How can i either use cwm on boot loop or install picunu/Ubuntu on good mkiiis without erasing jelly bean. I do not have pc. Can mkiiis w Linux s sound mkiiis?
Remember m a total noob.<br>Buy ou a beer? How?
Originally posted by moose m79 View PostLinuxium,. Thank you for your help .Here is what I have Two 802 mkiiis 4.1.1, one works flawless one stuck in booot screen after I hit recovery thinking it was a reset.<br>How can i either use cwm on boot loop or install picunu/Ubuntu on good mkiiis without erasing jelly bean. I do not have pc. Can mkiiis w Linux s sound mkiiis?
I don't think anyone has created a fully sd card solution for RK3066 devices where the kernel and RFS boot from the sd card regardless of the state of NAND on the device.
So I'd recommend you either buy a supported RK3188 device (or similar which you can find from reading all the various posts and googling a bit) and then try the link I provided (but first fully understand the limitations of Linux on RK3188 compared to RK3066) or find someone with a PC so you can try recovering your "stuck" device by flashing stock ROM (and look for all alternatives on fixing a bricked device) and then once it works you can try flashing a Linux ROM to allowing dual-boot but that's if you don't asphyxiate first from reading this far too long sentence that is devoid of punctuation or other opportunities to allow you to pause and take a breath.
Rk 3066 linux
Originally posted by linuxium View PostYour OP asked about MK802IV which is quad-core RK3188(T) SOC but now you require MK802IIIS which is dual-core RK3066. You can't mix and match across different SOCs like this as the compiled kernel for an RK3188 device will not work on an RK3066 device.
There are currently 3955 users online. 0 members and 3955 guests.
