Rk3188 quad core
Rk3188 quad core
Hi I'm new to all this, I've just bought this box off ****, 2gb DDR 8 gb NAND flash, quad core cortex A9, I've gone into system infor and hardware CPU, armv7 processor rev 0v7 is this right ?? And storage is only 4.3 ??? Shouldn't it 8gb? Sorry if this don't make sence I'm struggling with it aswell, lol, it running xbmc 12.4, is this the best version for this box? Sorry for so many questions on my first post, be gentle please!!!!Last edited by Taggarts; 13 August 2014, 09:19.Tags: None
Originally posted by ftype75 View PostHello, im no expert but I believe I got stuck with a few of these similar boxes. They will run fine if you don't load them with massive amounts off apps leave at least a couple of hundred mb`s space on the system.I prefer beyond xbmc 3.4 which can be found on here. Good luck.
Originally posted by Taggarts View PostThanks ftype75 the 8gb flash is that what is supposed to in the box, mine is only 4.3? Thanks, I'm not sure if the is the same spec I paid for thanks
System.img(Android 4.2/4.4) can take up 400MB-1GB
Boot.img takes up 16MB
Kernel takes up 16MB
Userdata.img can take up 1-2GB, This is all the installed apps and their data.
User.img takes up the rest of the space left over(in you case probably the 4.3GB) is empty space where you can copy files to, not install apps.
You can change these sizes by editing the parameter file you dump from the firmware.
There are currently 3030 users online. 1 members and 3029 guests.
