CS918T / Rk 3188T which firmware? How to root it?
    Hi all
    I'm new to the forum.
    Got a CS918T from ****
    CS918T :TV Box, Android 4.4, Rockchip Rk3188T 1.6GHz Quad core, 2GB RAM 8GB ROM, WiFi, Bluetooth ,2Mp Web camera, Microphone, RJ-45 , AV OUT XBMC
    Read about it here.
    CS918T is an Android TV Box powered by Rockchip RK3188 quad core SoC with the usual 2GB RAM, 8GB Flash, and various ports such as HDMI, USB, Ethernet,
    Seems to be a good little unit however I have found a few things that I'd like to change.
    1. Cannot set a lock screen there is no option
    Don't want anyone that has access to the box to have access to my google account.
    2. Camera is poor to be expected I guess
    3. Google earth does not zoom out using Logitech wireless keyboard with touchpad. Apparently only a scroll mouse will solve this.
    I'd like to use it with my tv to receive streamed media and do you tube and possibly Netflix or Usenet / torrents with the files saved to somewhere on my network or an attached Usb drive.
    Here are some pictures of the internals
    Can anyone suggest what alternative firmware would be suitable for this device?
    Any super clear guides on how to root it and or update the firmware?
    I'd also be happy if I could get it to boot into XBMC. For that matter does openelec run on this thing?
    I have not much experience with android besides mucking round booting android x86 of SD card.
    Happy flashing things and have used openwrt with router before but not much more than getting them going.
    So hello and nice to meet fellow forum members
    Hope you can help me
    Cheers
    Super
    I see this PCB the first time and it seams to be totally different to the PCB's which are supported by custom roms (and these PCB's also not all are supported by custom roms because of different NAND and Wifi/BT chip sets)...
    RK3288 Devices
    - Overview BOX (LINK !)
      Is there some sort of system info app / tool that I can run to report all the hardware?
        Hy друзья!
        Это мое устройствоClick image for larger version
ID:	435835Click image for larger version
        does not work
        and
        PC does
        help PLS
          Originally posted by Super View Post
          Hi all
          Read about it here.
          Cheers
          Super
          if you're just looking to Root, there are a couple of 1-click root tools which are compatible with almost all chinese tv boxes...
          i used Root genius@ www.shuame.com/en/root
          just plug it to your PC via the OTG port, install drivers (if needed) enable USB debugging and click root.
            Thanks for your reply.
            (I've learnt a bit more now and have now upgraded my nexus 7 to lollipop)
            What are the possibilities for different firmware for this box?
