share path: smb://10.0.0.9/sharename/
mount point: /mnt/cifs/
username: guest
password:
options: none
I can see the cifs folder where it should be, but I doesn't work, I keep getting the error.
Any help will be appreciated.
#!/system/bin/sh # Make sure networking is up before mounting while : do check_if_up=($(netcfg | grep -e eth0 -e wlan0 | busybox awk '{print $2}')) if [[ (${check_if_up[0]} = UP) || (${check_if_up[1]} = UP) ]]; then break fi sleep 1 done sleep 1 # Switch rootfs to read / write # Be careful after this. Misplaced commands may # brick your system busybox mount -o rw,remount / # Create Mount Points mkdir /data/media/0/mov mkdir /data/media/0/e # Mount shares busybox mount -t cifs -o username=XXX,password=YYY,iocharset=utf8,noserverino,nounix,file_mode=0777,dir_mode=0777 //192.168.178.11/02_Movies /data/media/0/mov busybox mount -t cifs -o username=XXX,password=YYY,iocharset=utf8,noserverino,nounix,file_mode=0777,dir_mode=0777 //192.168.178.11/E /data/media/0/e # Switch rootfs to read only busybox mount -o ro,remount /
There are currently 2053 users online. 1 members and 2052 guests.
