Which of those boxes to buy for XBMC/KODI?
    Hi folks!
    It is my first post here. I did read many threads here because the Android box i bought (PROWORX C13, similar to Bluetimes MX5) had extreme audio/video sync problems. Sometimes it worked, but with many movies it just got aout of sync with adelay of at least 4 seconds. Mostly after fast-forward the sync was totaly gone.
    So i tried to make a firmware upgrade with the MX5 firmware with the hope i could root it and work on the sync problem. Now the box is bricked and all suggestions here did not work.
    This is why I want to ask wich box to buy. I thought these could be nice candidates:
    1) http://goo.gl/eQwE1M
    2) http://goo.gl/bNPtJc
    3) http://goo.gl/bLVGoh
    4) http://goo.gl/VK36uP
    This should be S802 chipsets which should be quite fast, and the GPU should also work with XBMC/KODI. What would you guys suggest? Yes/No - and if yes which?
    thanks for your answers in advance
    Lets see
    1= fake
    2=looks good
    3=mx3 with 1 gb-ram
    4=m8 with 1 gb-ram
    From these choice's .. i would take 2
    Goodluck
      -2- or mx3 2gb ram not 1gb
        I would prefer the round boxes with S802 like Beelink S82/Tronsmart S89/MEasy B4A. They have better quality than the square ones.
          1's not as bad as it looks, you should be able to flash it with Linux, which makes things easier/ more stable if all you want is XBMC
            I must say the bee-link M8B s802b is a seriously good buy especially with the support given on freaktab from bee-link engineer oman and freaktab dev team.
            I got mine from the bay £66.50 delivered from a UK source in 2 days
            Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
            Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
