Long time lurker,first time posting.Header pretty much sums it up.Accidently wiped the cache partition during a flash (it sits right below "factory wipe").Thing is M8 works just fine only issue (maybe) is that at the end I get this error "Failed to locate customized_data folder..skipped".How do I fix this if need be.Lotta knowledge here so I thank you in advance.
Help!!...Wiped Cache Partition
Hi everybody,
Long time lurker,first time posting.Header pretty much sums it up.Accidently wiped the cache partition during a flash (it sits right below "factory wipe").Thing is M8 works just fine only issue (maybe) is that at the end I get this error "Failed to locate customized_data folder..skipped".How do I fix this if need be.Lotta knowledge here so I thank you in advance.Last edited by Avee08; 14 August 2014, 22:11.Tags: None
P.s Wiping cache and factory data before the installations is essential...
Yes that latest ROM from ENY the recovery ALWAYS tries to use that TAR file to preinstall apps. Why they did that I have no clue! But the stock ROM used that for preinstalling /data stuff. On my ROM as part of debloat I removed that TAR file so you get that error in recovery now.
Originally posted by Finless View PostYes that latest ROM from ENY the recovery ALWAYS tries to use that TAR file to preinstall apps. Why they did that I have no clue! But the stock ROM used that for preinstalling /data stuff. On my ROM as part of debloat I removed that TAR file so you get that error in recovery now.
to be exact it installs xbmc
JustMeBugs are Sons of Glitches!
JustMe
There are currently 1026 users online. 0 members and 1026 guests.
