Cube U30GT Clockwork dem
Re: Cube U30GT Clockwork dem
Not certain what you are asking here?900Supersport
freaktab developer
He wants a video showing the new ROM and CWM in action.
I am usually pretty good at doing videos but just have not had time to do them for my ROMs either.
Originally posted by Finless View PostHe wants a video showing the new ROM and CWM in action.
Bob900Supersport
freaktab developer
I've used backup and restore a few times I'm the last day on my cube mini as I experiment with flashing from Linux. It's worked flawlessly for me.
Have you been editing, adding to or in any way changing the backups?900Supersport
freaktab developer
What I have heard is that like the Yuandao N101, there is a SDcard corruption issue. I cannot do backups to my external sdcard on my Yuandao N101 because fo this issue.
Please take the sdcard you backed up to and plug it into windows and do a disk check on it. If the sdcard is corrupt CWM will fail every time. Then to see if you have this issue. Fix the sdcard and try another CWM backup. Then plug the sdcard back into windows and check it again. If windows said it has problems, they you have the same issue as the Yuandao.
On my yuandao what I have to do is backup to internal sd and then copy the CWM folder to external sd. No other way. FYI, mopst believe this is a hardware issue and cannot be resolved by a ROM. It has to do with the sdcard formatted as FAT32.
Now the yuandao does support sdcard as NTFS and this stops the corruption issue. However I have been unable to make CWM work with NTFS formatted sdcards.
A change of theme by clockwork
Snakekiller has kindly done a little themeing for me. To do this he has changes the following files
/system/appLatinIME.apk
Setting.apk
SystemUI.apk
/system/frameworkframework-res.apk
I've packaged these up as a clockwork update.zip, I've done this for my cube mini but I expect it should work fine with other tabs. Download it from the link below, this should save it in the sdcard (internal) in the Downloads folder.
NOTE Ceptic informs me that this does not work on the cube mini with JB.
Clockwork update -> update_snake.zip (11.47 meg)
For maximum safety when you start recovery you would backup the system, then if it all goes wrong or you don't like the change you can restore. if you skip this step you should be OK.
To updateNow reboot to recovery or start in recovery
navigate and select 'install zip from sdcard'
navigate and select 'choose zip from internal sdcard'
navigate and select Download/
navigate and select 'update_snake.zip'
confirm you want to apply the change
wait a minutes or so as the update is implemented
navigate and select 'Go Back' until you are at the main menu
Select reboot
Once the tab restarts you will notice a few changes including the status bar, system settings and keyboard.
Hope you like it.Last edited by 900supersport; 30 September 2012, 22:12.900Supersport
freaktab developer
Originally posted by 900supersport View PostSnakekiller has kindly done a little themeing for me. To do this he has changes the following files
Setting.apk
SystemUI.apk
Select reboot
Hope you like it.
That's not good, have you opened up the cube before?
I've edited the post above warning about applying to JB.
Another thing to try maybe before dissassembly is connect the cube to the pc and start the flash tool. Now restart the cube and keep an eye on the flash tool, there is often a short interval when the cube is recognised when you wil be abl to click thw restart in flash mode button.900Supersport
freaktab developer
Originally posted by 900supersport View PostThat's not good, have you opened up the cube before?
Ceptic
Not certain from that last post button think you are sayiing you think you damaged a cable while fixing the volume contols. Hopefuly a careful assambly and inspection will identify the issue.
Feel for you with this, I'm wary of modding my u30gt h as I don't have the option of flashing to fix.900Supersport
freaktab developer
A couple of ideas if you thinly the tab is working but you have broken the ribbon cable to the screen.
Is the tab detected by your pc?
Is the hdmi working?
Is the tab visible to other wireless devices.
I've repaired tracks on circuit boards using one of the prototyping pens with metallic ink. If you do identify the issue is a cracked track on the cable it could be worth a try.900Supersport
freaktab developer
Originally posted by 900supersport View PostA couple of ideas if you thinly the tab is working but you have broken the ribbon cable to the screen.
Thanks for the advice but thankfully I didn't need it and the ribbon cable is intact because the screen is working fine. I stupidly wiped the NAND and lost my backup so I am now enjoying your ROM and reinstalling the apps that I used often. I like this forum and how helpful everyone is... but I've liked everything today after fiing my tab and avoiding a $200 loss!
Chris
Chris
There are currently 5242 users online. 2 members and 5240 guests.
