Powerful Amlogic S802 chipset + 2GB DDR3 RAM
The specifications for our new android 4K TV box with Amlogic S802 cpu:
Operation System | Android 4.4 | ||||||
Language | Chinese,English...Multi-Language support | ||||||
CPU | Quad Core Amlogic S802 ARM Cortex A9 | ||||||
GPU | Eight core ARM Mali-450 GPU up to 600MHz+(DVFS),OpenGL ES 1.1/2.0 and OpenVG 1.1 support | ||||||
SDRAM | DDR3 2GB | Optional:1GB | |||||
Nand Flash | 16GB Nand Flash | Optional:4G/8G/32GB | |||||
Storage Extension | N/A | ||||||
Network | IEEE 802.11 b/g/n 2.4G/5.0G,RJ45 10M/100M/1000M | ||||||
Module | RTL8188/AP6210/AP6330 | ||||||
Power Supply | DC 5V/2A 3.5mm DC-in | ||||||
Interface: | |||||||
HDMI Out | HDMI HDMI2.0 to support maximum 4Kx2K display | ||||||
USB Port | 3 x USB Host | ||||||
Data Output | 1 x SPDIF | ||||||
Card Reader | N/A | ||||||
AV Out | 1 x 3.5mm Headphone Jack | ||||||
Network | 1 x RJ45 10M/100M/1000M | ||||||
Power Supply | 1xDC Jack | ||||||
Antenna | External WiFi antenna | ||||||
Media Parameter: | |||||||
Audio Container: | MP2/MP3/WMA/WAV/OGG/OGA/FLAC/ALAC/APE/AAC | ||||||
Audio Out | HDMI Data Output | ||||||
Video Decoder | DAT/MPEG/MPE/MPG/TS/TP/VO8/ISO/AVI/MP4/MOV/3GP/FLV/MKV/M2TS/MTS/M4V/WMV/ASF/RM/RMVB | ||||||
Video Encoder | H.264,H.265,VP8,MVC(1080P) | ||||||
Resolution | HDMI1.4 up to 4K,1080P | ||||||
H.264,H.265 Data Rate: | Up to 60Mbps | ||||||
Text-Reading | Support TXT、LRC、PDF、Html、Htm、EPUB…etc formats(Depends on APK install) | ||||||
IM Software | Support Skype/QQ/MSN/GTALK (Depends on APK ) | ||||||
Office Software | WORD/EXCEL/PDF(Depends on APK install) | ||||||
Other Parameters | |||||||
Operating Temperature: | -10~40℃ | ||||||
Storage Temperature: | -20~50℃ | ||||||
Humidity Environment | 5%-90%(No condensation) | ||||||
Certification | CCC,CE,EMC,FCC,Wi-Fi |
JustMe
