Help please beyond xbmc
Hi guys I've tried different versions of the release with the problems, I'm playing jarhead 2 after 10 mins the pictures freezes, the films continues to play and, I've added a photo to try give you an idea what I mean, I've put xbmc 12.3 played the same stream and it worked with no problems, can some make my day and help with please, thanksTags: None
The "10 minute freezing bug" is well documented in most rockchip threads I read.
It's mainly a problem with large mkv files.
The solution is to try a more upto date build of xbmc which has the fix incorporated.
From this forum look at spmc or from minix x7 forum try wasser xbmc 1.3 / KODI - helix if you need passthrough.
With the above builds you need to add your favourite repositorys.
Another option could be to try ultimate xbmc but I've not used it so don't know if it has the mkv fix?Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Originally posted by ant View PostThe "10 minute freezing bug" is well documented in most rockchip threads I read.
Originally posted by Taggarts View PostThanks ant, I've tried the ultimate (free) version which had the same problem, will at the ones you mentions and try them thanks for your reply, thanks,Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
There are currently 2477 users online. 0 members and 2477 guests.
