In brief
First off the controller looks & feels very nice.Its well built & feels good.
It comes with a rechargeable battery that should last at least at least 5-7 hours of game play,it does come with the battery partly charged but i would recomend charging it befor use.
so i plugged the 2.4Ghz receiver into my beelink m8 pressed the T power button on the controller (big blue button) & it was paired instantly with the Beelink m8 witch was very nice no messing about It also worked perfect with my minix x8-h & my cx-919,it automatically connects in A mode (android) witch is good for most games.
Specification
- Connecting: Tech 2.4Ghz Wireless
- Bluetooth: NO
- Plug-and-Play: YES
- Vibration Dual-Motor: YES
- Cover Range: Up to 10M (30 Feet)
- Frequency Range: 2400MHZ - 2483MHZ
- Channels Bandwidth: 1MHZ
- Maximum Transmitter Power ODBM
- Battery Capacity: 600mAH
- Working Current: 11-20mA
- Standby Current: 33µA
- Charging Current: 300mA
- Interface USB: 1.0/2.0/3.0
- Compatible System: Win7/Win8/VISTA/PS3/Android
My Unboxing of this new device, Iv been waiting a wile to try something like the tronsmart mars G01.
Un boxing it was very well packed & fits neatly in the box with everything i needed in there.
Mars G01 Controller
wifi receiver
micro usb cable
OTG cable
User manual
Carry case
First impressions
The first thing I noticed when I picking up the Tronsmart Mars G01 was how well built it looked & felt,The buttons are the same layout as the xbox controller but it seems to fit & feel nicer in the hand with the rubber sides.
Setting up the Tronsmart Mars G01
Was very easy,insert the wifi reciver into your tv box/phone ect & simply press the blue button on the controller thats it setting up compleat.
The battery life
Is good too iv had about 6 hours game play so far & its still working well but im going to recharge it now as i dont like to let any device run compleatly down.
Games iv tested so far
Dead Trigger (A MODE)
Asphalt 8 (A MODE)
GTA vice city (A MODE)
Beach buggy Blitz (A MODE)
Sky riders (A MODE)
Sonic 4 epc 1&2 (A MODE)
Shadowgun (D MODE)
Modern Combat 4 (x MODE)
More to follow
To my amazement they all worked perfect with no lag at all & not having to do any reconfiguration the controller
Conclusion
Very impressed with this device & how easy everything is to get connected if your a big gamer this is the device for you
