New P4 bricked
New P4 bricked
upgraded to rileyrom 1.4, seemed ok but after an hour its bricked. trying to reload the rom, android tools see the tablet (blue square), 'boot start' ok, 'maskrom start' ok, but gets to test device and just hangs on 100%, nothing at all on the tablet screen. Tried everything nothing seems to work, had two pipos before never had an issue. helppppp anyone pleaseTags: None
Why start two threads on the same subject?
Sent from my P1 using TapatalkRandy
rookie mistake
sorry riley, rookie mistake first post, not sure i posted so did it twice
tried the 1.3 and it loaded ok, so went to 1.4, it did work for an hour but bricked while watching a video. just tried 1.3 again and have the same result it hangs
download boot start
dowload boor success
wait for maskrom start
wait for maskrom success
test device start
test device (100%)....
Usually it is the USB connection that causes that. Make sure you are using Pipo's cable.
I'm mobile...so I can't look it up, but I noticed a post last night from tinydeal with the upgrade instructions for flashing factory firmware. It uses a different tool...but there are new rk drivers for the 3288. There is a download link on that thread. You might try them and see if it makes a difference.Randy
If the custom ROM is going to brick at tablet, it will do it immediately. The tablet won't boot at all if there is a problem with the firmware. Since my ROM is pretty much rooted stock, with very little changed and very little removed, and others have reported the ROM works fine for them, I'm thinking that Amasterman's problem is a hardware problem...maybe a NAND memory failure or a CPU/GPU failure. Other users are reporting problems with the battery charging circuit, too...which could also have failed. I have experienced this on an M8 Pro tablet and was never able to bring it back to life.
The reason I'm thinking hardware is the problem is that as stated in post #1, he was using the tablet for an hour before the tablet failed. Since he was running everything at stock tolerances, no overclocking or underclocking or any other power related tweaks in place, it has to be something wrong in the hardware.Randy
There are currently 2697 users online. 0 members and 2697 guests.
